Need help on how to stop the hiss.
Discussion in 'Archived Threads 2001-2004' started by Ryan-Stone, Dec 7, 2002.
  1. Ryan-Stone
    Ryan-Stone Stunt Coordinator
    Oct 10, 2002
    56
    I figured out why i have so much his. Its my TV. Nothing hissis until my televisions is turned on. Im using a kenwood vr-06050 reciver and a hitachi ustravision TV. Is there any thing that i can do so that the TV wont make the speakers hiss?
  2. Christopher R.
    Christopher R. Auditioning
    Apr 5, 2002
    9
    Ryan,
    When you say,"until the tv is turned on", do you mean when you switch to that input or do you mean when the tv is turned on it causes hiss even when listening to some other source. ie..cd, tuner..anything non-video. The hiss is probably caused by processing. Try turning off pro-logic on your receiver and/or any 'surround sound' processing your tv might have (if your using the tv to get a signal to the receiver).
    Christopher R.
