NEED HELP NOW!! new comp doesn't work
Discussion in 'Computers' started by Troy*H, Oct 23, 2003.
  1. Troy*H
    Troy*H Stunt Coordinator
    Feb 13, 2003
    156
    Ok I just got done building my new computer. Everything was going fine. I was installing xp. I took a bathroom brake and when I came back my computer was off. Now when I try to start it , it only stays on for about 3 seconds and then turns off. What could have happened. What should I do!! Please help me.
    Thanks Troy
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    yikes that sounds scary! When weird crap like that happens to one of my older puters it's because I left it on a long time, so I have to leave it off for a full night to let it cool down. Maybe the CPU fan is spinning to slow and the mobo bios is shutting the system down as a safeguard? If you wanna try a quick fix go to CompUSA and buy a PSU to see if that's the problem. Return it if it isn't.
    What CPU/motherboard setup is this?
  3. Troy*H
    Feb 13, 2003
    156
    my setup:
    amd xp 2500+
    ASUS A7V8X-X mobo
    ati 9800 pro
    1 gig 3200 ddr ram
    wd 80 gig 8 meg cache
    the rest dosn't matter[​IMG]
  4. SteveMc
    SteveMc Stunt Coordinator
    Feb 3, 2001
    230
    110
    I would double check all your conncetions inside your box, especially, CPU and fan, RAM, and video cards.
  5. DaveJJ
    DaveJJ Stunt Coordinator
    Jan 20, 1999
    79
    Hi Troy, I would suggest you check you power connects or check your power supply. Are you using a new or used case??
