need help:multi room set up (1 Viewer)
Raymond L
Need some help deciding how to set up a multi room system. I'm running a Denon 3802 reciever. I was thinking of a couple of different options. 1. running another amp to pre out then to a switcher, or, 2. using an A-bus system. The amp that was recommended to me was the Audiosource Amp1a,a QLS6.1 switcher, and Russound volume controls,speakers are undecided.This is the way I'm leaning right now. Any help or suggestions would be helpful.
Thanks R
Rich G
How about running the preouts into another receiver/integrated amp in the other room?
Raymond L
I actually have 6 zones that I'm trying to cover,and would like to keep all the equipment in one spot.I have run all the wire (speaker and cat5)to positions where i would add volume controls. I'm just trying to decide which way to go for the best bang for the buck.
Thanks R
linda19798888
