Need Help Mounting Speakers (1 Viewer)
Van_D
im quite new to this so forgive me if this topic and been discussed already....i just recently purchased the Kenwood HTB-505 and the two front speakers dont have holes in the back so i cant mount them on the wall. does anyone know of some equipment or method that will enable me to do so? thanks
JoelM
Cut a speaker hole in your drywall. Place a support beam between your 2 studs(usually 16 inches apart) and walla you have in wall speakers. If you have dipole's make the board stick out (sort of like a shelf). I thought it was simple, running the wire up the wall was a lot easier, and it looks damn good.
mightyhorse
