Need Help Hooking up new SVS
Discussion in 'Beginners, General Questions' started by Chris^C, Jan 11, 2005.
  1. Chris^C
    Chris^C Auditioning
    Oct 4, 2004
    10
    Hi, I'll start off by saying that I'm the proud new recipient of an SVS 20-39 PCi. I'd like to say it sounds awesome, but I've yet to figure out how to get sound to come from it! I have it hooked up to my yammy 5760 with a white RCA type wire (the Bash amp has a left and right input but the receiver only has a single subwoofer pre-output so I had read here that this method would work). Anyway, i'm not sure if the hookup is the problem or if I need to run YPAO again. I'm sure you're asking why I haven't already tried this out. Well, the answer to that is I live with 2 idiots that have lost 2 of my 3 remotes. HOW DO YOU LOSE A REMOTE SO EASILY?! It was gone within the first week. So I can't run a set up without the remote, but I'm trying to avoid replacing it for 50 bucks. Am I going to have to buy another remote or is there just a problem with the wire hooking it up? Thanks in advance
  2. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    5,610
    Somehow you have to let the receiver know it has a sub attached. You would probably have to run setup to do it. If there is no way of running it without the remote, I suppose you have to get a new one.
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    universal remotes are cheap, and may function with your receiver to get into the setup modes of your receiver.
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Your setup menus are all available from the front panel.
    With my Yamaha 793 they told me to set all speakers to SMALL, and subwoofer to BOTH to get the LFE output to work.
