Need Help from Yamaha owners - especially RX-V2090
Discussion in 'Archived Threads 2001-2004' started by CarlV, Jan 24, 2002.
  1. CarlV
    CarlV Stunt Coordinator
    May 11, 2000
    135
    I recently bought a used Yamaha RX-V2090 receiver for the bedroom.
    I am having trouble getting any sound from it... the sound that comes out is very faint. I can hear sound if I put my ears next to the speakers.
    When the seller demoed it it worked perfect but he had it connected through his TV. He would control the volume thru his TV. I would guess this has something to do with the problem I'm having.
    I've tried the manual but no luck. THere's no reset button that I can find.
    Carl
  2. joe logston
    joe logston Stunt Coordinator
    Oct 24, 2001
    130
    try a & b speaker button i thank you have it on b speakers
  3. CarlV
    May 11, 2000
    135
    It's not a/b speakers, I've checked it and it's conntected on a. I did push b and nothing happened.
    I only have a pair of mains connected to the receiver.
    Carl
  4. ken thompson
    ken thompson Second Unit
    Jun 5, 2000
    251
    I was going to say check the mute but i believe "mute" flashes on the screen when engaged. I will continue to think about your problem. Seems like ive had this problem in the past. ill try to remember.
  5. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    I have the RX-V2092, check to make sure the jumpers in the back which connect the pre-amp to the main are in (or even there). They are just a pair of thick, bent wire.
  6. Wayne A. Pflughaupt
    Aug 5, 1999
    6,185
    51
    9,110
    Katy, TX
    Wayne
    Carl,
    Make sure the tape monitor is not engaged. If the tape monitor LED is on, push the button and then you should get some sound.
    Wayne A. Pflughaupt
  7. CarlV
    May 11, 2000
    135
    jeff,
    the jumpers were connected, it worked fine at the sellers house.
    Wayne,
    Good idea I will check the tape monitor tonight and report back.
    thanks
  8. CarlV
    May 11, 2000
    135
    I tried the tape monitor, it didn't do a thing. I'm stumped.
    Any other ideas.
    Carl
  9. joe logston
    Oct 24, 2001
    130
    try the fm radio in the receiver doudble check all your plig ins and speaker wires you got a pair of ear phones try that to thank you, joe
  10. joe logston
    Oct 24, 2001
    130
    what do you have to hook up to the receiver dvd, cd, tape,tv,
  11. CarlV
    May 11, 2000
    135
    Fm tuner works but it's very faint just like the dvd player. I'm just playing a cd thru the dvd player.
    Carl
  12. CarlV
    May 11, 2000
    135
    I just checked the manual.
    I think I know what the problem is now.
    It is the pre amp jumpers as mentioned by jeff
    Maybe they came lose when I packed it.
    Anyway I will try to locate some jumpers and let you guys know.
    Thanks guys
  13. Wayne A. Pflughaupt
    Aug 5, 1999
    6,185
    51
    9,110
    Katy, TX
    Wayne
    Call 1-800-4-YAMAHA and order some new ones.
    In the meantime, a set of RCA cables patched across the jacks will get you up and running.
    Wayne A. Pflughaupt
  14. CarlV
    May 11, 2000
    135
    Wayne,
    Patch cables worked like a champ.
    This receiver sounds excellent.
    Thanks everybody
    Crrl
