Need help from a Sony Wega Owner (1 Viewer)
Mike Kao
I have a KV-27FS12, I want to hook up my tv to my receiver but I can't see behind the tv and it will be a big nuisance to shift it around so I can... unfortunately I lost my manual as well so I was wondering if anyone could help me out? I do know the audio out is the right most connections in the back, but I just need to know if the right or left channel is on top of the other?
Thanks!
Steve Schaffer
Steve Schaffer
Mike,
If you can maneuver a small mirror back there, check the color coding on your audio output jacks--the left is coded white, and the right is red.
Reginald Trent
You don't need to see left or right to determine which is which. Just connect the RCA cables to the TV then touch the metal connections at the other end with your fingers. You should hear a hum listen to left and right speakers on your TV to hear which is which.
Reddevil_23
