Need help fixing overscan on Sony Bravia 50KDFE50A12U
Shawn Watson
Shawn
I need to know how to get into set-up so I can correct the over-scan. Any help would be very much appreciated.
Thanks in advance.
Shawn
GlennH
Glenn
You posted this in the wrong area of HTF. Even though it's "HT Hardware" this area is really about HD sources, not displays. You may want to post over in the Display Devices area.
I was also going to suggest you check out AVSForum.com for help, but it looks like you already did that and some other forums as well. Hope you solve the problem.
Druiz23
