Pablo Abularach
- May 27, 2002
Hi,
I'm just a newbie trying to build my system, thanks for taking the time on ready my thread.
I'm planning on hooking a JBL PB12 with NPS1II and a ONKYO SR600. I have a Wega 34' (with S video, composite and component hook ups).
So here are the questions
1) Does cables matter, a fiend told me that the cables the are sold in Radioshack could get almost the same performance than a MONSTER Cable.
2) What are your thought of Acoustic Research in cables, are they any good, or should I go for Monster.
3) I havent decide how I'm going to hook the video lines, I don't know if should go S vidio or Component. If I go with component should I see much difference compare to svideo (my TV isn't HDTV). I heard that the difference could be notice only in HDTV systems.
4) Suggestions on DVDs, right now I have a PS2 as DVD, but I don't like the qty, so I'm planning on buying a new one, I'm looking for something between $100 to $300, my TV isn't Progresive scan, and I don't need it to be THX certified.
Thanks in advance for any replies,
Pablo Abularach
Pablo Abularach
