thoozer28
- Aug 16, 2008
- Paul
Hey guys, I am in desperate need of help here.
I got this huge ass Technical Pro Nuke 15" sub with max 1500 watts and two 500 watt powered out puts for speakers. What im trying to do is connect my pc to the sub and the sub to my passive speakers. I got a 1/8 to split RCA going from my pc to the line in under the subwoofer section, all im getting is bass which should be correct, but im not sure where to put the other RCA connection coming from my PC since there is only one line in for the woofer( this is white). There is a red RCA connection under the subwoofer out. There are also two (red/white) RCA connections next to this under a label satellite, the top two are line in the bottom two are line out. There are two Speakon powered out-puts one L and one R below the speakon connections are a set of 2 female bare wire connections (-,+ and +,-)
So I really need to get the mids and highs going and Im not sure what connections need to be made, I also dont know if it makes a difference but my speakers i want to output to are a pair of Yamaha NS-A838's which have a maximum of 200 watts(not sure if the 500w powered outputs is too much for the speakers have).
Sorry this would have been alot eaiser if i had my camera. Thanks so much guys
