jorge386
- Jun 22, 2011
- wagner8
I just bought my first house. I would love to really like to go crazy and wire all the rooms and yard but on a tight budget. I figured I would start with the living room I included a drawing of my setup. Which is the best way to go in adding a home theather to this room. I have a xbox already and use fios. I would like a 7.1 surround sound system. Should I use in wall speakers, floor standing, cube speakers. Also curious about hoooking up a home theather pc or will the xbox do fine. Can I use both and run a external blu ray drive to closet from pc if needed. I would like to leave cable box and other components in the closet. Please help want to run wires and hook ups before I move in and fix up. Thank You!
