Chad Isaacs
- Feb 20, 2000
ok,i am choosing between a lcd/dlp fp and a rptv.
as far as size(screen,and rptv box) i am leaning toward fp.
what i need help with is....
I want a 8' wide screen.how far does the projector need to be from the screen to do that?
how far should i sit from the screen?i have 16' to work with
if it is 8' wide,how tall does it need to be?my celings are low at 7' and i have 3' tall speakers so the screen either needs to be a. only 4' tall or b. fit inbetween the speakers.b is probably what i will end up doing.
8' is just what i think i would like the best.that will be my starting point.i might go bigger or smaller once i actually get the projector.when i do get it,i will just use a white or grey wall as a screen until i figure out what works best.
"And the horse i rode in on?"...Marge Simpson
