Need help choosing receiver
Discussion in 'AV Receivers' started by gianfrancs, Oct 11, 2003.
  1. gianfrancs
    gianfrancs Auditioning
    Oct 10, 2003
    2
    I just wanted some advice on choosing a receiver for a home theater and wanted some opinions/experiences with the hardware. I currently have a 65"mitsubishi widescreen TV with an Energy encore speaker system. The room is 15 ft deep and 20 ft wide. Standard 8 ft ceilings. I want to stay in the $500 range (but naturally, the less expensive the better) and have narrowed it down to the following:
    Onkyo 601
    HK AVR325
    Marantz 4300
    Denon 1803
    I'm running everything off of a sony str-de945 but would like a more quality receiver and to upgrade to component outputs. Any advice would be helpful. Thanks
    [​IMG]
  2. dale^g
    dale^g Stunt Coordinator
    Sep 4, 2003
    60
    my vote is for the HK. the HK525 is coming down in price and is available under $600. you might be able to get a refurb for less than $500 and they are a great deal. which ever HK you get you will be happy.
