Need Help Choosing an SVS
Discussion in 'Speakers & Subwoofers' started by Chris Hovanic, Sep 7, 2004.
  1. Chris Hovanic
    Chris Hovanic Supporting Actor
    Jan 3, 2003
    545
    Well Im getting real close to upgrading to a SVS and Purchasing a Denon 2805 as well.
    The Wife actually likes the looks of the Cylinder over the box so that helps my budget quite a bit.
    Now the two choices I have picked are the 25-31PCi and the 25-31CS+
    Now the CS+ is a bit cheeper than the PCi but it does not include an amp.
    Would my old Technics Pro Logic Receiver be enough to power the CS+ ? (Im not sure on the power ratings of the receiver but I will dig out the manual when I get home.) If my receiver is 8Ohm will it drive the 4Ohm SVS? Would I be able to bridge my old Reciever for more power? If so how? Which input would I plug the LFE from the Denon into?
    My Room size is about 12' wide and 12-13' deep and is open to my kitchen in the back (you can see pics by clicking the link in my sig). My speakers are Energy Take 5.
    I will be using the Sub for about 90% Movies and 10% Music.
    All My Gear is in a closet at the rear of the room so Im a little concerned with heat build up running 2 amps/receivers. This may be what pushes me to the PCi.
  2. Craig Chase
    Craig Chase Gear Guru
    Oct 21, 2002
    1,669
    71
    1,610
    Pennsylvania
    Craig
    Chris.. Get the PCi ... Get the PCi... Get the PCi...
    [​IMG]
  3. JohnSmith
    JohnSmith Supporting Actor
    Apr 8, 2003
    554
    No your Technics would not be sufficent since sub drivers are 4Ohm, and I very much doubt you can bridge the Technics. And even if you could you wouldn't want to (bridging limits low current drive ability) If possible try to get the PC+ it's a better sub, and it's active. Since your room opens up to another. For a passive system you'll need a better mono amp and the SVS Bass Interface box.
    If possible remove the door to the closet, or leave it open during use. You could install a couple of large, slow rotating fans at the back to help with airflow. You only need a slight breeze just to remove the hot air from the general area of the unit.
  4. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    The 25-31PCi is a better choice, considering what you have available for a sub amp. It will have plenty of volume/power in that size room.
    Ed
  5. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    Or DIY.........
  6. Craig Chase
    Oct 21, 2002
    1,669
    71
    1,610
    Pennsylvania
    Craig
    Cam... I have missed you. We have a great job opening at our dealership. We need a talented guy to handle remodeling our showroom... you do great work and don't charge for labor... I figure you are the PERFECT guy ! ...
    [​IMG] [​IMG]
  7. Edward J M
    Sep 22, 2002
    2,031
  8. Chris Hovanic
    Jan 3, 2003
    545
    Thanks Guys
    I may try to go with the PC+ but not sure my Budget will allow.
    It really doesnt get super hot in the closet running just the one amp. But if its a warm day I do tend to leave the door open.
    Thanks for the help!
  9. Cam McFarland
    Feb 6, 2004
    699
    Great, I am currently unemployed. Just tell me where your showroom is and what do you sell, unless you are just being a d***.
  10. Cam McFarland
    Feb 6, 2004
    699
    Yes, Bravo.....you did a good job of an unprovoked
    attack on a self-proclaimed idiot...shows great
    character.
  11. Craig Chase
    Oct 21, 2002
    1,669
    71
    1,610
    Pennsylvania
    Craig
    Cam ... It was humor... thus the [​IMG] [​IMG] ... smile and have fun with us... [​IMG]
    Now, About that showroom job... [​IMG]
  12. Cam McFarland
    Feb 6, 2004
    699
    Yes very amusing.....point out where I EVEr claimed to be good at construction or work for free so that I may laugh with you.
    Or, may I just arbitarily put together some comments that
    I feel to be humurous about you & you would have fun as well.
    It would be different if I knew you or if it was the first time!!
    I never claimed to have one or know of one either!!
  13. Cam McFarland
    Feb 6, 2004
    699
    n
  14. Chris Hovanic
    Jan 3, 2003
    545
    thanks all for bustin up my thread.... I really appreciate it [​IMG]
  15. Cam McFarland
    Feb 6, 2004
    699
    My apologies Chris....:b
    When I said DIY, I was only trying to suggest building your own.
    I had no tools & little construction experience & am
    absolutely thrilled with my Tempest & how it sounds.
    If you have the time & desire you can really come out with a great value.
