Need help choosing a Home Theater Package (1 Viewer)
Aman
Ontario,Canada
Amandeep
Hi Everyone,
I received a quote from a reputable installer here in Toronto, this is my first home theater so need some help selecting the best package.Installation is going to be in my basement(has a few windows so quite a bit of natural light). I think i am ok with the video package from the little bit of research i have done online, but i really need help selecting the audio package, it will mostly be for movies and music.Should i go with a particular brand?, how does Speaker Craft compare to Klipsch etc.
Many Thanks in advance.
Cheers
Aman
Listing all the details below:
Video package:
EVO8K-ZAWL-135-1.3 Aurora, Perforated, Nano-edge, Led backlit, Ambient light rejecting Screen.
JVC LX-NZ3B
PRG universal mount
Subtotal: $7,800
Audio package 1 - 7.1: Klipsch
(3) PROTHX8000L
(4) Klipsch CDT-5800-C II
(1) SPL 120NAB
(1) Marantz SR5015 8k Receiver 7.2 Receiver
Subtotal: $6,400
Audio Package 2 - 7.1: Martin Logan
(2) Martin Logan Edge
(1) Martin Logan Axis
(4) Martin Logan IC6-HT
(1) Martin Logan Dynamo 1100X
Subtotal: $7,750
Audio Package 3 - 5.1 Surround sound
(2) SpeakerCraft Aim Cinema 3
(1) SpeakerCraft LCR5 Five
(2) Dynamic Audio Labs KVSC – 80
Denon S650h
Subtotal: $3,800
Audio Package 4: 9.1 Dolby atoms
(2) SpeakerCraft Aim Cinema ONE
(4) Dynamic Audio Labs KVSC – 80
(2) Martin Logan IC6 - HT
Denon 3700h
Subtotal: $5,200
Dave Upton
Audiophile
Houston, TX
Dave Upton
First regarding video, you might want to inquire about the cost to upgrade the projector to the NX5/RS1000. It's a way better unit.
Moving on to audio:
My opinion is that Klipsch is a well known brand, but doesn't sound nearly as good as people think it does when compared to better speakers. If you only plan to watch movies, it will be fine - but doesn't do great for music. Speakercraft is a generic in-wall or in-ceiling that is incredibly marked up by builders - not a brand I would recommend and would actually tell you you avoid.
If you want to do this correctly, I would take a variation on Package 2, and buy your own sub (that sub is overpriced) from SVS or HSU audio. I would also try to get your receiver to be an Anthem instead of a Marantz, since the installer looks to be a Paradigm/Anthem/Martin Logan dealer. The installer could also use in-walls from Paradigm to save you some cost.
Aman
Ontario,Canada
Amandeep
Hi Dave,
Many Thanks for your reply, greatly appreciated!
They recommended JVC LX-NZ3B as i have a lot of natural light in the room ,but i will enquire about NX5.
Will go with Option two and get a price on paradigm and anthem as you suggested.
Cheers
Aman
Chris_Wilson3
