MattCPT
- Jun 13, 2002
I had once purchased a Velodyne Sub(don't recall model) eight years ago when I bought my main speakers (Def Tech BP-30s) and I promptly returned it because I found the sound to be "BOOMY" not at all musical. I preferred the sound of my main speakers alone. I had since given up on the idea of adding a sub. After reading posts on this forum regarding subs like SVS, HSU, Adire, etc... I'm beginning to feel as though I'm missing out on "MUSICAL" bass that will also add to my home theater experience.
My speakers say that they go down to 18Hz, and I always thought that I was getting accurate bass reproduction down to that level. I now understand that my speakers may go as low as 18Hz, but the sound may not be audible. I certainly don't "feel" the bass unless the I play my speakers hard.
I love the sound of my speakers, but if I could gain tight, accurate, and powerful bass then I want to.
My entertainment room is 13 x 23 x 8 with the back of the room open to stairs and the dining room. The room is tiled with poured concrete floors, walls, and ceiling. I live in a townhouse. I'm looking for help deciding between the following speakers. I and/or my wife have already ruled some out because of dimensions, looks, performance, or price.
SVS PB-1 - looks like it should be a great performer with an excellent price. I'm not thrilled with the dimensions, or the looks, but it's still a contender.
Def. Tech Pro-Sub 200TL - I'm not considering this one just because it's the same maker as my speakers. I read excellent reviews on audioreview.com. The dimensions and looks are great. I wonder however if the performance will be what I'm looking for. Do you think this will provide the power that my room requires? Should I believe a post from an owner of the Pro-Sub 100 that says he has compared is with SVS and doesn't feel that he is missing anything? I would love to hear from someone that has heard this sub, not just assumptions(thanks).
Aperion Audio SW-12 - Love the looks, the dimensions are fair and the price is good. Does anyone know how this sounds? Is it quality? How would it compare to the other two?
I ruled out HSU because my wife doesn't like the look of the VTF-2 and I wouldn't buy the VTF-3 when I can get the SVS for much less. I ruled out the Adire Rava because I read less than stellar reviews, and the Darhman on the fact that it is bigger than I would like. I also ruled out the ACI Force because of price.
Any help would be appreciated.
