Need help burning an mpeg file to dvd
Discussion in 'Computers' started by George_fsf, Oct 23, 2004.
  1. George_fsf
    George_fsf Agent
    Jun 24, 2003
    33
    Hi, I downloaded some dolby digital 5.1 trailers, and I've been trying to burn them to dvd using nero 6 but it records them in dolby 2.0. What can I do to burn these files on dvd keeping the 5.1 sound?
  2. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    hard to help you with the information that you have provided.
    what type of files are they? Do you have a liscensed ac-3 codec? are you sure that you are burning dvd's or are you burning vcd's?
    check out wwwdvdrhelp.com and do a lil' research.
  3. George_fsf
    George_fsf Agent
    Jun 24, 2003
    33
    the files are mpeg 2 with 5.1 sound, the software I have is Nero burnig rom 6 and I am trying to burn the to dvd not vcd.
    Thanks.
