Greg P
- Jan 7, 2001
I just cut out the baffle for my sealed 1503.
I have already braced the 4 sides of the box and the internal braces.(Turned out well)
The cut out for the 1503 is 14 in. The cut looked good, (I was cutting from the back side of the baffle)however, when I looked at the front the jigsaw went at and angle out some how. The screw holes all line up but not with the face of the baffle(The front measurements are around 14.25. What can I do to cure this? I was thinking i could either get schilacking, or make a paste of mdf sawdust and glue and add it to the baffle. I hope I dont have to make a new one. Got any advice?
