Need help ASAP w/ Dish Network setup...I can't find the 119 satellite
Discussion in 'Archived Threads 2001-2004' started by Kevin Alexander, Dec 22, 2001.
  1. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    110
    I get a green lock signal for the 110 satellite (a somewhat weak 50), but I cannot find the 119 satellite. Everything is plumb, but no signal after 3 days of trying. What do I do?
  2. Charles Dodge
    Charles Dodge Auditioning
    Feb 22, 1999
    12
    You initially should be aiming your Dish 500 (I guess you are using a dish 500) with only the 119 LNB connected directly to your satellite receiver.
    If you are doing this and picking up the 110 satellite, then you have your elevation set about two degrees too high, and your dish aimed slightly to the east.
    www.dbsforums.com is a website which deals strictly with DBS issues, you can get a lot of trouble-shooting advice from professional installers and very knowledgeable hobbyist there.
