akash_b
- Mar 6, 2002
hey lads
im just after some feedback on this home ent setup... basically what u guys think... good or bad
TV: Sony KV-36FS70U 36" WEGA W/Screen
Amp : Sony STR-DB 1070, 6.1ch encoding
Speakers: Sony SA-VE705 satelite speakers+sub
Dvd player:Sony DVP - S536D,5.1ch encoding
as you can see, we;re a bit of a fan for Sony stuff
also whats the best way to hook all these badboys up?
at the mo,ive got:
the speakers going into the amp, and NOT the sub. instead the sub connected to the amp independantly.
the tv connected to the amp with audio L and R gold plated cables, going from the audio out on the tv, to the audio in on the amp
the dvd player connected to the tv through a standard scart,and going into the amp via a digital co-ax, also with JVC audio cables (same as with tv)
sky digibox (not sure if u guys know what this is,cos im from england and alot of these posts seem to be coming from America, BUT the digibox is the digital receivor that decodes digital signals via satellite into a digital quality picture onto my tv) connected to amp via same audio L and R cables.
any comments, suggestions, advice??
methinks for some reason that the dvd player is connected wrong, coz it has 5.1ch decoding outputs on the back, the standard audio L and R outs, digital co-ax and optical connections all on the back. at the mo, im only using the co-ax and the standard audio outs.... is this producing the best results???
cheers guys
akash
at the mo,ive got:
cheers guys
akash
