Need HDTV suggestion where space/cost a big concern. (1 Viewer)
Matt.R
I have promised my parents an HDTV for Christmas. Unfortunately, they just redecorated their family room, and I have a brand new Armoire style TV cabinet to deal with. Here are the dimensions I have to stay within: 44"W x 24.25"D x 42.5"H. Obviously the depth is the concern. I would also like as large of a screen as possible, as the room is rather long and narrow, and the seating is probably a good 15 feet or more from the TV. I am not partial to any particular technology, I just need a nice HDTV that will fit in the Armoire, which is hopefully within my budget of under $2000. Any suggestions?
Matt.R
Good suggestion, though way on the high end of my price range. I had passed over the Samsung, thinking that the 46" would be too wide, but it squeaks in at 43.1".
Ted Lee
i second the samsung dlp, but if you want something more in your budget, try the zenith 44" lcd.
since you want the biggest screen possible, you'll definitely want to look for something with speakers on the bottom.
RobRWA123
