Need Hard Disk Partitioning help
Discussion in 'Computers' started by StephenK, Feb 5, 2006.
  1. StephenK
    StephenK Stunt Coordinator
    Jun 1, 1999
    226
    Hey all,
    So I have a 2nd hard drive that already has 70gigs of Games on it. (Mostly Mame). I have another 60gigs free on it that I would like to partition as a separate drive and then password protect.
    Is there a good app out there that will let me partition the drive without re-formatting? and then enable me to password protect the 2nd partition so that I can mount and unmount drive at will?
    p.s. This is so I can let my small nephews play the games, but keep my other personal data protected.
    Thanks for your help.
    Steve
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Partition Magic is the standard app for this kind of thing, however it's not free.
  3. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    714
    110
    SF Bay Area
    Christian Behrens
    Something like PartitionMagic will let you create the additional partition (make sure to backup the drive beforehand), whether it can password protect it for you I don't know.
    -Christian
  4. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    Not sure if you can password-protect a partition, but you can certainly apply the relevant access permissions to the drive letter.
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Yeah, just partition it, and set the security on it for certain users, and then just have the nephews log in under a user (will most likely have to create a new user login) that can't access the new drive.
