Need good indoor antenna for Onkyo 696
Discussion in 'Archived Threads 2001-2004' started by Jake T, Oct 3, 2001.
  1. Jake T
    Jake T Stunt Coordinator
    Jul 4, 2001
    225
    The one that came with doesn't pick up anything. Mysetup is in my basement. And suggestions on what's out there.
    [​IMG]
    Jake T
    --"The Things You Do In Life Echo In Eternity"
    ----Russel Crowe, Gladiator
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i've had some exposure to the terk antennas. specifically the fm wedge and the tower. they both worked pretty well. plus, i don't think they were too expensive.
    You step in the stream,
    But the water has moved on.
    This page is not here.
  3. Jake T
    Jul 4, 2001
    225
    Thanks for the quick reply Ted. I've heard that Turks were good also.
    Anything else worth looking at out there?
    [​IMG]
    Jake T
  4. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    One of the best out there is the fanfare fm-2.
    Look here: www.fanfare.com
  5. Jake T
    Jul 4, 2001
    225
    Thanks Brian but I'm looking for somethig smaller to put in the basement.
    Jake T [​IMG]
    Jake T
  6. Brian Corr
    May 10, 1999
    535
    Just for reference, I have mine mounted on the wall behind my drapes.
  7. Jake T
    Jul 4, 2001
    225
    Great idea Brian, I never thought of that. Thanks. [​IMG]
    Jake T
  8. Alex F.
    Alex F. Second Unit
    Aug 29, 1999
    377
    I tried the Terk FM Pro and own both the Terk Pi and Fanfare FM-2G. Here in central NJ (about 30 miles from midtown Manhattan), the best reception was provided by the Fanfare. In my home, it actually works best positioned horizontally and taped behind a piece of furniture.
