Need apartment satellite dish mounting help!
Discussion in 'Archived Threads 2001-2004' started by Nathan_R, Apr 5, 2001.
  1. Nathan_R
    Nathan_R Supporting Actor
    Dec 4, 2000
    717
    Hi guys,
    How do you apartment dwellers mount/stand your satellite dishes outside? I'm on the 15th floor and our dish is duct taped to a table on the balcony outside. There's gotta be a better way than this. I don't want to drill into our exterior brick, as the landlords will probably kill us. I was trying to find something heavy enough not to blow away
    to use a a stand for the dish. I switched from a round dish to an oval one yesterday, so naturally this one is a litte heavier and harder to balance.
    Any other apartment dwellers care to share their installation methods?
    Thanks.
    ~~Nathan
    ...just lost drunken men who don't know where they are and no longer care.
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    I don't live in an apartment, but I know a lot of guys who cement the pole in a large bucket and attach the dish to the pole...
  3. Nathan_R
    Dec 4, 2000
    717
    Mike,
    Thansk for your input!
    I thought about the bucket, but then there's the SAF (Spouse Approval Factor). Both my wife and I would like to make something moderately attractive, or at least not ugly. I almost went the large flowerpot/cement route, but I'd hate to ever have to move that thing. I'm thinking about some sort of mount for the railing, but I'm having trouble designing anything stable for our 5" round balcony railing. Looks like another experimental trip to Home Depot.
    ~~Nathan
  4. Timmy
    Timmy Stunt Coordinator
    Sep 22, 1998
    160
    Someone sells a "planter" that doubles as a dish mount. It may be easy to DIY; and the wife will have yet another plant to care for!
    The dirt acts as ballast.
  5. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Buy a sheet of plywood and cut it down to the size of your balcony. Maybe even double it up. (Two 3/4" screwed together) Then mount the dish on the stand.
    Glenn
  6. EddieN
    EddieN Agent
    Sep 23, 2000
    35
    Hey Timmy,
    Do you know where I could get details on the planter that doubles as a sat stand ?
    Otherwise I'm gonna end up with a bucket, some quik-rete, and a pole.
    - Eddie
  7. Timmy
    Sep 22, 1998
    160
    Eddie, I read about the dish "planter" on another web site. There was a link to the manufacturer; but I can not find it.
    From what I remember it looked like; it was a 1.5 ft by 3 or 4 foot wood box planter with clamps on one of the ends.... clamps to hold a short piece of mast pipe. And I think instead of clamps/mast-pipe usage; you could opt for 2 ft wood post that the dish mount could be attached to.
  8. Richard Driskill
    Richard Driskill Stunt Coordinator
    Apr 1, 2001
    55
    Nathan,
    What about purchaing a 3' X 3' X 1/4" piece of genuine "Diamond Plate" steel to mount the pole base to? It would be heavy enough, you could buy a little throw rug to place inbetween the base mount and the plate before you attach the base, and vola! no offensive "structure", looks like a nice throw rug with a dish sitting on it, great stability, wont rust, and you can even position chairs and whatnot on it, and you wont get a hernia if you try to move it.
  9. Richard Driskill
    Apr 1, 2001
    55
    Opps, meant to say "aluminum" not "steel". And don't forget to ground the dish and cable to something, like the metal railing (It should be tied into the buildings main beam structure).
