Need an equalizer that is not rack mounted
Discussion in 'Speakers' started by EdNichols, Jan 21, 2005.
  1. EdNichols
    EdNichols Second Unit
    Feb 15, 2003
    372
    I am looking for an equalizer that will go with the components in my entertainment center. Does anyone know of an equalizer for a subwoofer that isn't rack mounted, that has a black front, and has slide controls?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Audio Control. However, they’re expensive.
    Another option is an older dbx model, like this 1513. They came with removable rack ears. This particular model is switchable between stereo 15-band and mono 31-band (which is the way you’d want to use it).
    Parametric EQs are better for subs than the graphic models you're looking for, but you can find them with your requirements. Your best bet is probably a half-rack model like this Symetrix or this ART. I think dbx used to make a half-rack model, too – you might check e-Bay from time to time..
    The half-rack models typically have removable rack ears, but the downside is that they usually only have three bands (due to their reduced size). So to adequately equalize your sub you might need two of them daisy-chained.
    Wayne A. Pflughaupt
