need advise
Discussion in 'Playback Devices' started by Gaelen, Jul 27, 2004.
  1. Gaelen
    Gaelen Auditioning
    Jul 26, 2004
    3
    Hey, im rly new to the whole HT world...but im moving houses in 2 months, and i would like to turn my room into a HT...now first u must know that i am pretty young, so i do not have a ton of money to throw around...what i was thinking was getting a benq pb6100 projector and a Sony DAV-BC250 5-Disc Home Theatre System. here are my questions.
    1. do you think it is a good idea to get the audio in a package like with the Sony DAV-BC250 5-Disc Home Theatre System? I do not have eneugh money to go all out on speakers and buy each one indavidually...this system seams powerfull eneugh with its 680 total wats.
    2. with the benq pb6100 i know there is only 1 s-video port. If i wanted to hook up many things that use s-video, what should i buy so that i can switch them. i.e. i would like to hook up my satelite tv to it, my ps2, my dvd player (duh) and perhaps my vhs.
    3. I will be using a white wall for now, as i have a pretty tight budget. is there any specific paint i should use to paint the wall with?
    thank you very much for you time [​IMG]
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Welcome to HTF, Gaelen. Since you're asking for specific advice on an entire system I've moved your post to A/V Sources. The Basics area is for general discussion at the beginner level. Thanks, and good luck on your search.
  3. Pieter_V
    Pieter_V Auditioning
    Jul 14, 2004
    4
    well, I can tell you that you don't have to paint your wall into white.
    I have the BenQ PB6100 also, and I project my movies on a wall that is painted in an earthcolor. grey-brown.
    To connect more s-video channels to your projector I should buy a cheap A/V-receiver, that is a little better than a sony, with some more options than you have now.
    You can also connect something with composit or SVGA-cable (if possible)
    But that's your choice.
    Hope I helped you out.
  4. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Yeah, Pieter is right. The best bet for switching would probably be a lower-end home theater receiver. Instead of getting the Sony HTIB, you might consider a lower-end Yamaha receiver. If you did that and got something like the Klipsch quintets speakers and Dayton 10" sub from Parts Express you'd probably end up just a little higher than the Sony HTIB, but you'd have higher quality components with the benefit of adding more inputs to your system.
