I just bought a new router, the Linksys WRT54GX4
SRS 400 router.
This baby packs a lot of power and puts out an
incredible amount of range -- far better than the
D-Link 624 Wireless Router I had before.
This concerns me greatly as with so much range
I am afraid that neighbors will tap into my
wireless connection.
I need to secure my connection. I have a few
questions I hope you can assist with....
First, I hate setting up or fiddling with
routers. One mistake can lead to the loss of
all your initial settings or even a router
lockup that can render your unit permanently
useless.
I need to know EXACTLY what has to be done
in the most simplistic terms possible.
1. Is there software that I can buy that
will automatically secure my network? I'd
rather go that route than risk going into
the router settings and doing something I
shouldn't be.
2. If you recommend I do go into my router
settings, where EXACTLY do I go? Does the
password have anything to do with the HEX
CODE settings, and if so, how do I pick those
numbers? If not, do I just put in any worded
password I like?
Now....regarding the LAPTOP on the receiving side...
3. Once I password my network, what happens
when I try to log into it with my laptop?
I would love to have some sort of screen come
up on the laptop that asks for the password (such
as what you get when using WiFi at a hotel).
4. If a password screen on the laptop is an
impossibility, where do I go in the network
area to put the password I need for the laptop
to receive the WiFi signal?
I'd like to make this process as easy as possible
as my brother sometimes is visiting my home with
his laptop and I'd like logging him into my
network to be as hassle-free.
Would greatly appreciate any advice that you
guys can provide on easily securing my WiFi
network.
SRS 400 router.
useless.
shouldn't be.
password I like?
network.
