Need advice please...
Discussion in 'AV Receivers' started by NikoVarsan, Oct 6, 2003.
  1. NikoVarsan
    NikoVarsan Auditioning
    Sep 12, 2003
    6
    I recently purchased a new receiver for my living room,
    a Sony STR-DE995, and I moved my Sony STR-DE925 to my
    bedroom with a cerwin vega avs-5.1 speaker system for
    surround sound. I also have a Sony dvd and vcr in my room,
    but no cd player. I could just use my dvd player, but
    prefer not to. I have a Sony shelf system in there that I
    was using for a stereo before moving in my 925, which has
    an optical output for cd's. My receiver has an optical
    input. I was considering hooking the two up and seeing
    if it would work, but don't want to risk damage to
    either component. Does anyone know if this would work or
    not? Any thoughts or suggestions would be appreciated.
    Niko
  2. Nick.H
    Nick.H Stunt Coordinator
    Sep 18, 2003
    118
    Yes it will work, just plug them all in without the power on, and make sure that the channel you are on with your new receiver is getting audio from that optical port, I use my xbox and satellite box with optical.
    Its what it is designed for.
    have fun[​IMG]
  3. NikoVarsan
    Sep 12, 2003
    6
    Thanks for the reply Nick, but seeing that the source is from another receiver(the shelf system), and it has it's own
    amplified output, will that overload my receiver? I know that a regular cd player with optical out would work fine,that's how my dvd player is hooked up. I'm just not sure that hooking these two together would be safe.
    Niko
