Need Advice - Panasonic (1 Viewer)
dusty
Im curious to know which DVD player is worth keeping. I own a Panasonic RV-31S and I just bought the Panasonic SC-HT290D HT-in-Box package that includes a 5 disc DVD changer, dolby digital/dts reciever, and speakers. Does anyone know what model dvd player that is, and also which one would you recommend keeping?
Thanks in advance!
JohnnyG
I believe the changer that comes with the 290 package is functionaly identical to the DVD-CV51. The CV51 is basically a changer version of the RV-31.
The only thing I don't see is mention of MP3 capability in the unit that comes with the 290, but I wouldn't be surprised if it actually did play them.
John Golitsis
Next Big Thing Electronics
Tom Johnson
It is not the same as the 51. The one that comes with the HT in a box is an elevator type changer. It is similar to last year's DVD-CV40. The DVD-CV51 is a rotary type changer. There is no equivilent stand alone model with an elevator type changer.
dusty
Great, thanks for the replies! I will probably stick with the RV31.. i cant wait to see what a 192k mp3 sounds like with the optical connection. i hope the setup is halfway decent (for a newbie!) that comes with the sc-ht290..
JohnnyG
Tom, you're getting the systems mixed up. The SC-HT290 is a seperate component system with seperate A/V receiver and 5-disc carousel DVD changer. See it here:
Link Removed
The SC-HT70, 80 and 90 are one-piece systems with elevator changers.
John Golitsis
Tom Johnson
I stand corrected. I looked up the SC-HT90, not the 290. The DVD player in the SC-HT290 is in fact a silver DVD-CV51.
dusty
So it IS the CV-51.. Any one know if that plays mp3 files? i will have to research to find out which one to keep..
