David Wilkins
- Jul 5, 2001
I've been way out of the loop concerning audio hardware, for about two decades. Recently I've been cramming as much knowledge possible, but there's so much quality stuff out there, that I feel a bit overwhelmed, and I keep raising the ante, little at a time. I'll be building the system from scratch, so there's no need to over-concern about fitting into old existing parts.
Here's the picture:
The system will be used approximately 60/40, home theater / CD based music listening, with a very wide range of musical tastes. So far as sound, I prefer purity and accuracy over added coloration.
I've considered the following, but am way open to suggestions: Denon AVR-4306, and Sherwood Newcastle R-965. Also, I've noticed some intriguing set-ups in the area of power and pre-amps, from the likes of NAD, Parasound, etc., but that field is less known to me, having never owned separates. The AV receivers I've mentioned are both 7.1, but I have nothing against a solid 5.1 set-up. Your advice and knowledge would be most welcome!
Also...if it helps...I've been thinking about B&W DM603-S3's for the mains, and 600-S3 for the center. The speakers, too, are wide open to change.
Here's the picture:
