Need advice on the best multisystem widescreen TV
Discussion in 'Displays' started by colin.w, Dec 16, 2003.
  1. colin.w
    colin.w Extra
    Dec 14, 2003
    17
    Hi
    I'm looking for a decent multisystem (NTSC,PAL) widescreen TV be it projection, plasma, LCD for about under $3000 (if that's possible). I don't want the screen smaller than 34" but it doesn't have to be massive. If anybody has any suggestions and where to buy it from in the USA, or even can point me to any reviews of models that fit that criteria I would appreciate it.
    Currently I have a 28" multisystem square Panasonic TV
    Thanks in advance for any help.
    Colin
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Do you have light control?
    And a way to mount a heavy projector?
    If you, a CRT projector at your price range (used of course), will take pretty much any reasonable resolution and refresh under the sun.
    You'll be far more limited with many other displays, as very few are truly multi-sync.
