Need advice on surround spkr purchase
Discussion in 'Archived Threads 2001-2004' started by JoeDur, Dec 15, 2001.
  1. JoeDur
    JoeDur Auditioning
    Dec 14, 2001
    5
    I am looking to buy a pair of surrounds for about $500/pair.
    I had considered Def Tech BP2X's to match my BP10's. I was told that these speakers should be wall mounted. This is not going to happen in my house. Should I consider the Def Tech ProMonitor 200's - even though they're direct radiating? How about other makes ( I was told this does not matter much for surrounds) ?
  2. Jeffrey_Jones
    Jeffrey_Jones Second Unit
    Nov 6, 2001
    283
    Hello,
    I have an older pair of Def Tech bipole surrounds and I love them. I do have them wall mounted, but this is not a requirement. You should have them several feet above the listening position, but again, room layout often dictates where the speakers can go. I think you would like the dipole or bipole spearker better for HT...maybe less so for multi-channel music.
    Jeff
  3. balwinder
    balwinder Extra
    Dec 6, 2001
    20
    If you have Fry's electronics near you then check out Polk Audio RT800i speakers... they droped the price to 499 from 799... pretty good deal.
    - Balwinder
