Miranda Jones
- Sep 12, 2000
We are hopefully going to be buying a receiver (Denon 3802) and a set of speakers soon, and are probably looking to get a set of Paradigms (Titans for the fronts, CC-170 for the center, ADP-170s for the surrounds, and PDR-12 for the sub...basically their System Three recommended setup).
My question is about the surrounds. Due to trying to fit a large computer desk and the couch/home theater stuff into the same living room, our TV is in a corner, and the couch is sort of diagonal in the middle of the room. There is actually a 3-D Home Architect image of the room at http://www.thefruitbowl.org/images/misc/livingroom.jpg. Our friend has suggested that we could mount the surrounds in the corners of the room (in the picture, over the desk and over the recliner) and use a sound meter to balance it properly, or we could mount them on the ceiling above and behind the couch.
Which setup would be a better placement...up on the ceiling near the couch, or on the sides but relatively far from the couch?
