Hello everyone, I need help choosing the correct in wall speaker for my HT. I am planning on going with the H/K 525 reciever and due to the room design and WAF (wife acceptance factor) I will be using in-wall speakers all the way around except for the center speaker. I already have a velodyne spl1000 sub which I have been extremely pleased with.
I have narrowed my choices down to two different in-wall speakers; the PolkRC85i ($250) and the B&W CWM500 ($400). It seems like I would be getting a lot more speaker for the money with the Polks but I honestly do not know how these two speakers compare. I would be open to considering other in-wall speakers as well.
What would you recommend out of theses two speakers? What other speakers should I consider in this price range?
Here are the PolkRC85i specs:
Mid/Woofer 1 - 8" Diameter (20.32cm)
Dynamic Balance, mineral filled Polymer cone with rubber surround
Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance, metalized soft dome in swivel mount
Overall Frequency Response 30Hz - 20kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 - 100 w/channel
Efficiency 90 dB
Size 14" H x 10" W
(35.56cm H x 25.40cm W)
Cut-out Size 12-3/4" H x 8-11/16" W
(32.38cm H x 22.07cm W)
Mounting Depth 2-7/8" (7.30cm)
Here are the B&W CWM500 specs:
Dimensions Height: 228mm (9 in)
Width: 175mm (6.9 in)
Depth: 85mm (3.3 in)
Freq. Response 55Hz - 20kHz ± 3dB on reference axis
Sensitivity 88dB spl (2.83V 1m)
Power Handling 20 - 100W into 8 ohms on unclipped programme
Drive Units Unit 1: 1x 125mm (5 in) Kevlar® cone bass/midrange
Unit 2: 1x 25mm (1 in) high frequency
Crossover Frequency 3.5Khz
Cut-out size
(without pre-mount) Height: 212mm (8.3 in)
Width: 156mm (6.1 in)
Cut-out size
(with pre-mount) Height: 217mm (8.5 in)
Width: 161mm (6.3 in)
Efficiency 90 dB
Size 14" H x 10" W
Cut-out size
Cut-out size
