Need advice on cleaning a screen
Discussion in 'Home Theater Projects' started by Todd_Brown, May 30, 2004.
  1. Todd_Brown
    Todd_Brown Second Unit
    Oct 7, 2000
    389
    My 3 year old daughter apparently touched my Stewart Firehawk screen. In very light sections of a film I can see her finger trails down the screen (its very distracting). Anyone know the best way to clean these smudges without damaging the screen? They are smack in the center and trail down.
    Todd
  2. Rutgar
    Rutgar Second Unit
    Jan 17, 2004
    495
    I have a Stewart Greyhawk screen. I would think that the Firehawk could be cleaned in the same way. According to the manual, you can clean the screen using a solution of mild detergent, and water. Rub lightly using a sponge, then blot with a damp sponge to absorb excess water.
    Your problem is exactly why I bought a retractable screen. When not in use it's rolled up, out of harms (kids) way.
    - Rutgar
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Just be glad your daughter did not use pen (ink) like my boys did on my last screen. [​IMG]
  4. Todd_Brown
    Oct 7, 2000
    389
    I used a slightly moist cloth, worked like a charm.
    Todd
