Joe McCabe
- May 6, 1999
Ok, I'm building a theater room in my basement.
I have the TW65H8O, which will be built into the wall, so that only the screen is visible.
Here's what I need to know from you guys.
1.) I want to upgrade from a SD9000 DVD Player to a progressive scan model, what would be a good one to go with?
2.) I need a HD STB. What the best choice for the TW65H80?
3.) I need a complete surround package. Any suggestions??
4.) I'm also planning on getting a Pronto, will it be able to control a remote light dimmer? Also would it be possible to integrate it so if I push "play" on the DVD player, the lights would dim automatically?
Also, I'd like to stay within a $5000.00 budget.
Thanks for any help in advance.
