Dave F
- May 15, 1999
Ok, I am fed up with cable.
I have a HDTV, and I'm looking at moving from cable to satellite, but I'm somewhat overwhelmed by my options, and could use some advice. At some point, I would also like to add a personal video recorder (such as Tivo/Ultimate TV) and a high-def receiver into the mix. These aren't "must-haves" right now, but I'm just keeping future upgrades in mind.
Am I better off getting separate components for each, or getting some of the combo units, such as the Direct TV/Ultimate TV boxes? If combo is the way to go, should I get dish/PVR or dish/HD? Are there any boxes that have all 3?
Any advice or links to good info sources would be helpful...(models to consider/avoid is also helpful)
Dave
Dave
