Wilson Ortiz
- Dec 21, 2005
Hi Guys,
I'm finally ready to start building my Home Theater, and I need some advice on do's and don'ts
I have a room in my basement which is going to double as my laundry room and my HT room. The room is 21x11 and since I'm going to stack up the washer and the dryer I'm only going to loose a couple feet 4x4 in the rear right corner, that will leave me with a 17x11 rectangular space. Plus the space next to the laundry room; here is rough sketch of what it looks like.
_________Window_____________Small___________
|............5x2 3ft.......................Window............|
|............from floor....................1x2 1ft............|
|............................................from ceiling.......|
|__________....................................... ...........|
|Laundry.....|.................................... .............|
|Room........|.................................... ..............|
|4x4..........|................................... ...............|
|_________|_____Door_______________________|
I can't go too crazy with materials and equipment a conservative number will be between $2K and $3K for material and the same amount for HT equipment Roughly $6K in total.
I know is not much but i can't afford a mega HT right now and besides i just want it for my family and the occasional guest.
I hope to put together something that's going to sound good and look nice. I believe I can accomplish this by planning ahead and doing things right from the start.
Materials:
I have heard that there is special sound proof insulation?
Can I find that at Home Depot or Lowe's?
Sheet-rock is there special kind? & how thick should it be?
Floor I've heard wood is better for sound? can ceramic tile do the job? is a lot easier to maintain.
Electrical outlets how far apart and how many?
Ceiling? sheet-rock or drop ceiling i would like recess lighting?
Equipment:
Projector I found the InFocus SP5000 $1K any suggestions?
Receiver I have a SONY STR-555 SE series 5.1 which i would like to keep but if the difference between 5.1 and 7.1 is what I think it is, then I will consider a new one I saw a Denon AVR-3805 for under $900 or if there is a way to upgrade my SONY?
Speakers I have been contemplating the Bose AM10 III about $900.00 which is a 5.1 and if I get the 7.1 receiver I can then add two more Bose speaker and connect them directly to the receiver, i'm just afraid that the Bose system is not going to give as much bass but that I'll leave it to the experts; I like the way they look and sound but if there is something out there better and in the same price range then i'm open to suggestions.
Equipment Position?
I'm having difficulty deciding where to mount the projector, at the beginning i thought about mounting it right next to the laundry room projecting towards the wall on the right of the sketch, I was thinking using that wall as the screen of the projector which brings up another ? Should I invest on Screen or I've heard of special paint that will work as well?
The problem I'm facing with placement of the screen and projector is that i would like to fit one or maybe two sofas or one sofa and one love seat with recliners.
Any advice would be appreciated.
The space right next to the Laundry Room can be the location for all the equipment and maybe a rack for the DVD collection any other ideas? for this space?
Thanks a lot and sorry for the length of this post but I just wanted to provide as much information as possible.
WilsonJ
Materials:
Equipment:
Equipment Position?
WilsonJ
