Need a rundown on movie poster frames
Discussion in 'Home Theater Projects' started by paul_r, Nov 3, 2003.
  1. paul_r
    paul_r Extra
    Jan 27, 2005
    20
    Can someone give me the rundown on movie poster frames? I am looking at getting a few that I can rotate posters in and out of. I do not have a budget for back lite frames. I have seen a front loading poster frame sold online for about 50 dollars. What I am concerned with is posters seem to come in different sizes. If I get a frame for 27" X 40" posters. How much room for error is there (ie will a 26.5 X 39.5 poster look good in this as well)? Also if you have a system for displaying movie posters that has worked well for you can you please share? On the same note if any of you have tried something and it did not work out well please share.
  2. Ed O'Neill
    Ed O'Neill Second Unit
    Mar 20, 2003
    333
    Paul,
    I found this company to be pretty informative about what type of frame to get. I originally found this company from a link at http://www.learnaboutmovieposters.com
    Here is a direct link to their site.
    http://www.hollywoodposterframes.com/
    I am probably going to order from them .
    This company does sell on ebay so sorry if it was the one you were talking about.
    Hope this helps
    Ed
  3. Glenise
    Glenise Supporting Actor
    Feb 5, 2001
    773
    2
  4. Ed O'Neill
    Mar 20, 2003
    333
    Is there an echo in the house...LOL
    I wanna give a shot out to my homegirl Glenise...
    Did you get my PM...Doesn't matter really I found what I was looking for. If you haven't please read just for fun
    Signed
    Ed
  5. Glenise
    Feb 5, 2001
    773
    2
    Ed,
    I miss read your email about Hollywood Poster Frames.
    I thought you said this company doesn't sell on Ebay.
  6. AlexanderS
    AlexanderS Second Unit
    Oct 26, 2003
    262
    I don't mean to hijack but Ive got a similar question. I just picked up a few posters from allposters and was wondering if there was an economical way to frame/mount the posters that I can find locally. I.E. going to a Michaels or some sort of craft store.
  7. Glenise
    Feb 5, 2001
    773
    2
    Maybe Hobby Lobby www.hobbylobby.com, or Ikea www.ikea.com
    Walmart www.walmart.com and Media Play www.mediaplay.com and sell inexpensive poster frames too.
    You also might try a local Joann's www.joann.com.
    Michael's has 50% off their framing and poster frames from time to time.
    Check your Sunday's paper.
    I plan on keeping my posters for many years.
    Check this thread out for important info.
    I did my research last year and found out the following:
    http://www.hometheaterforum.com/htfo...threadid=68609
  8. AlexanderS
    Oct 26, 2003
    262
    Some good ideas in that thread, thanks for the link. Ill probably end up with something like that metal frame for my posters. Ill check back if I can find anything locally. What do you all think the best way to fit a 26x39 poster in a 27x40 frame is?
  9. Eddie L
    Eddie L Stunt Coordinator
    Jun 15, 2003
    110
    Suncoast, at the mall, has some nice black frames for less than $20. For that price you don't even need to take them out and rotate, just buy a bunch. OK, so now you need a big closet.
    Ed
  10. David Broome
    David Broome Stunt Coordinator
    Jun 2, 2001
    226
    Glenise, you are the link queen. I'd love to see your Favorites menu [​IMG]
    Nothing new to add to the thread...
  11. Glenise
    Feb 5, 2001
    773
    2
    Thanks David!
    Alex,
    I'm not sure about the 26x39 poster but maybe using foamcore or something like that.
    I think someone used some sort of tape to hold a poster in place on the sides.
  12. AlexanderS
    Oct 26, 2003
    262
    Just in case anyone's curious, the ad for Michaels this week says they are giving 50% off custom framing.
  13. Bryan Williams
    Aug 3, 2001
    34
    If you have an Ikea near by, they have a good selection of Poster Frames.
  14. AlexanderS
    Oct 26, 2003
    262
    Well I went over to Michael's. They are nuts over there. They wanted 110 for a black frame and that was with the 50% off. I couldn't stop laughing at the poor woman behind the counter.
  15. Chris White
    Chris White Second Unit
    Feb 12, 1999
    391
    I bought four frames from SpotLight Displays and was very pleased with them. They look great and it's very easy to change out posters as desired. If you're planning on buying multiple frames, email for a quote and you'll get a discount. Here's a picture of three of my frames:
    Poster Frames
  16. BrianL Cush
    BrianL Cush Auditioning
    Nov 12, 2003
    3
    Can't post URLs yet, but check out American Frame.
    www americanframe com
    I've bought a couple frames from them in the past and the quality is excellent.
  17. Ed O'Neill
    Mar 20, 2003
    333
    Chris,
    Do those frames have a plastic front and a ph balanced foamcore backing?
    What exactly is non acrylic PETG?
    Thanks in advance
    Ed
  18. Chris White
    Feb 12, 1999
    391
    As noted on the website, they come with a non-acrylic lexan sheet (two per poster actually) and an acid free solid black backing. I guess since the backing is "acid free," that means it is ph balanced. I don't think it is foamcore, just some kind of paper.
    Beats me. The cover sheets are just some kind of clear plastic.
  19. Ed O'Neill
    Mar 20, 2003
    333
    Chris,
    what I really wanted to know was is the plastic front real thin or thick. and is the backing thin like paper or like a regular poster backing.
    ED
