need a recommendation for a multizone receiver... (1 Viewer)
PeterN
Just curious what you guys would recommend for multizone use. My friend has a Denon 3802 which seems to get the job done for what I need for both HT/Music/MultiZone.
Any others out there I should check out?
Jon_Welker
I'm using the second zone on my 45TX. Granted, just to power some outdoor speakers, but works like a champ. I think there is actually 2 ways to set this up on the 45TX. One way to power the 2nd set of speakers and use the same source for all speakers, or you can set it up to run a different source to the 2nd zone.
vasyear
