Need a Progressive Scan DVD player with Coaxial digital output. Help!
Discussion in 'Archived Threads 2001-2004' started by Frank_M, Jun 24, 2002.
  1. Frank_M
    Frank_M Stunt Coordinator
    Nov 16, 1999
    96
    Bought the Panasonic RP-62 on Sunday... and figured since previous Panny's had the coax, this one would. (Yes, it was an impulse buy!).
    But now it has to go back.
    I've seen two Sony models... the DVPNS700p and the DVPNS715p... anyone know the difference? Or if they're any good?
    I'd like to return the Panny tomorrow. Don't really want to spend much more than $200 (Paid $179 at Sears for the RP-62) but I also want to make sure I'm buying quality.
    Help!!
  2. Jon Bye
    Jon Bye Stunt Coordinator
    Jun 1, 2002
    65
    Canada
    Jon Bye
    if you want something that is free of the chroma bug then you could try the JVC xv s500 series if you don't mind the zoom icon stuck on the screen
  3. Gregg Z
    Gregg Z Stunt Coordinator
    Jan 15, 2002
    178
    The 700P is a good little player but it does have the chroma bug (the RP56/62 do not). Not sure what is new about the 715.
    If you can wait a bit longer, the RP82 is due out in August. It will have a coax out (as well as Faroudja processing and DVD-Audio). List is $279 and mail orders around $220.
    Gregg
  4. Kevin_W
    Kevin_W Second Unit
    Jun 22, 2000
    261
    110
    And if chroma bug isn't an issue, I think BestBuy is clearing out their Toshiba line to make way for the newer ones. You could definitely get a SD3750 for under $200 and I am almost certain it has coax output.
  5. Chris Brunner
    Chris Brunner Second Unit
    May 9, 1999
    440
    110
    I agree with Kevin. My Toshiba SD-4700 plays DVD-Audio also and definitely has a coax out. I think it's currently going for around $215 at Best Buy.
    c
  6. Lyle_JP
    Lyle_JP Screenwriter
    Oct 5, 2000
    1,009
    3
    I just got a brand new JVC 502SL for only $109 on uBid. Well, with their over-inflated shipping costs and tax it's going to cost me $140, but that's the best deal on this unit I can find anywhere.
    uBid seems to run 2 auctions per day on quantities of this player so it's worth checking out.
    -Lyle J.P.
