Need a piece for my projector mount
Discussion in 'Home Theater Projects' started by Mike LS, Dec 30, 2003.
  1. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    Got an X1 for Christmas and was in shock to see how much ceiling mounts are for those things [​IMG] [​IMG]
    Anyway, I took a trip to Lowes, knowing I could build something that would work just as well, and whipped up a pretty good looking mount. I'm just missing one piece......
    I need to be able to adjust the angle (toward the ceiling or floor) that the projector is pointing. I have it wedged to almost the correct angle, but the projected image is still a little lower than I want.
    What I'm needing is some kind of locking ball joint that will thread on to a pipe.
    Does anyone know of something that would work for this application, or a place that sells parts like this? Being able to adjust yaw, pitch and roll would be an added bonus, but not absolutely needed. I just need to adjust the image up and down the wall.
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    A panavise base might be what you're looking for:
    [​IMG]
    You can find them HERE.
    I'm not sure it'll accept threaded pipe, though.
  3. Mike LS
    Jun 29, 2000
    838
    That looks interesting. I can't tell from the website, but it doesn't look like it has any way of holding onto the shaft/pipe that is put in that hole in the top. Looks like when used as designed, the weight of the vice holds it in.
  4. Dave Poehlman
    Mar 8, 2000
    3,813
    The website mentions a flathead screw that fits in the bottom to "permanently" affix a vice head.
    Any way you could incorporate the screw?
  5. Mike LS
    Jun 29, 2000
    838
    Possibly.
    I'll drop them an email and see if I can get some more info.
