Need a new roof for my house. $7,000 out the window.
Discussion in 'After Hours Lounge (Off Topic)' started by ken thompson, Jun 13, 2003.
  1. ken thompson
    ken thompson Second Unit
    Jun 5, 2000
    251
    How many DVDs is that?
  2. Leila Dougan
    Leila Dougan Screenwriter
    Mar 27, 2002
    1,352
    Better question. . how many DVDs would you lose should the roof come crashing down or let a downpour of rain right in?
    I know it seems that spending that much money is for naught, but really, it's probably a good thing [​IMG]
  3. David-S
    David-S Second Unit
    Mar 18, 2001
    267
    at $18 a piece (rough average of new and old?) that's 390! [​IMG]
  4. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    Finally a unit for measuring collections. Mine is about 0.38 roofs.
    Holadem
  5. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    I just had a new roof put on about 4 months ago. Had to replace some damaged fascia board and starter board as well. All-in-all I was out 266 DVD's (at $18.00/ea) or $4,790.00.
    Peace Out~[​IMG]
  6. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    My house had cedar shake, very expensive to replace due to the fact that new ones have to be fireproof. I had a stone coated steel roof installed for $6k, goes right over the old shakes so there's no disposal problem. I just counted my dvds, and I've spent enough on them to have done the roof and gotten $1k in change.
    This stuff looks great-comes in different styles and colors, some of which can't be distinguished from real Spanish Tile until you get within 3 feet, and is guaranteed for the life of the original buyer or 50 years if you sell the house.
    It is metal so it does make indoor FM and TV antennas sorta useless because it blocks so much of the signal.
  7. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
  8. Steve Schaffer
    Apr 15, 1999
    3,756
    Jeff,
    The Voices went away 15 years ago, about 5 years after I stopped drinking[​IMG]
  9. JohnRice
    JohnRice Lead Actor
    Jun 20, 2000
    8,884
    235
    9,110
    Ken, what sort of materials are needed or being used, and is there structural damage that needs repair? That sounds just a bit steep. Of course, you have to be extremely careful when it comes to roofing contractors. Not a good place to skimp.
  10. Karl_Luph
    Karl_Luph Supporting Actor
    Apr 5, 2002
    974
    Hopefully, the new roof will increase the resale value of your home and maybe there's some way you can count it as a write off on your income taxes. At the very least,your home looks good & you know you won't be having to replace the roof for at least 15 years or so, depending on the type of shingle you went with and the weather!
  11. ken thompson
    Jun 5, 2000
    251
    Yeah, $7K is a bit steep but I didn't want to go with the cheapest bid. We are going with the nicer archetectural shingles. We are also having four skylights replaced with the raised glass panel ones as well as having some additional ventilation installed and the wood replaced on the chimney. So $7K is not all that bad I guess. It's actually $6,700 but I figure there will be some "extras" popping up along the way.
  12. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
  13. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    Another reason I bought an old house, tile roofs.
    My roof is 80 years old, and will last a lot longer than I will.
    The house is also 12" thick stone walls, which will also long outlast me.
    It seams that new house are being built for a 30 year life. I will never buy a new house.
  14. ken thompson
    Jun 5, 2000
    251
    I would think any well maintained wood frame house should last 70 years or so. But I get your point and wholeheartedly agre. Our house is your basic wood framed house built in 1983. It's still in great condition. The new roof will really make the house shine. It's basically the last "old looking" part left to be redone. I cant wait. We're going with black tiles. Should look sharp.
  15. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    Interesting, my post from yesterday is gone....oh well, try again.
  16. ken thompson
    Jun 5, 2000
    251
    Our house gets tons of shade so it shouldn't be too bad. Plus with the added ventilation they are putting in hopefully that will offset the additonal heat absorption some.
  17. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
    my post from yesterday is gone as well...
  18. ken thompson
    Jun 5, 2000
    251
    There is certainly a difference in construciton quality between wood homes built 100 years ago the ones built today. I'd say a 100 year old wood frame home will likely last longer than a brand new one built today. Pity.
  19. Matt Heebner
    Matt Heebner Stunt Coordinator
    Jul 2, 2000
    241
    I would tend to agree. My house in Milwaukee, WI (big weather swings!) is over 80 years old, and is in excellent shape. For example, the walls are plaster over lathe board (try and punch through it and you will more than likely break something in your hand), the moldings and doors, door frames are solid oak. The cabinets in the kitchen are maple, and there are hardwood floors through out. The exterior is brick. If you were to build a house with these types of materials and craftsmanship today, it would be very expensive, and I personally don't think that the craftsmanship would even come close.
    OTOH, there is some major downsides to these things. Between the exterior walls and lathe board is absolutely NO insulation....I can feel cold drafts on very cold days. Hanging pictures on plaster walls can be a pain, considering the plaster has a tendency to chip into an even bigger hole! The plaster gets settling cracks in the corners....some say it "adds" character, I don't care for it. And the biggest disadvantage to owning an older home...they require alot of TLC. Houses this old like getting lots of attention, and there is always something that needs to get done or update....although after 8 years here, it's finally starting to slow down a little [​IMG] .
    Matt
  20. Greg Morse
    Greg Morse Stunt Coordinator
    Jul 13, 1998
    156
