Need a new pre/pro
Discussion in 'Archived Threads 2001-2004' started by Robert Standefer, Jul 27, 2001.
  1. Robert Standefer
    Robert Standefer Stunt Coordinator
    Sep 14, 1999
    85
    Here's my current setup:
    Sunfire Cinema Grand amp
    MartinLogan Aerius i mains
    MartinLogan Cinema center
    Polk Audio f/x 500 surrounds
    Sony TA-E9000ES pre/pro
    I'm looking for a new pre/pro to mate with my amp. Can anyone suggest some pre/pros for me that have:
    DD and dts
    Balanced outputs
    Balanced input (not a requirement)
    analog passthrough (not a requirement)
    Coaxial or optical digital out
    Built-in tuner (not a requirement)
    Some of the pre/pros I've been eyeballing include:
    Theta Casa Nova (used)
    Sunfire Theater Grand II (used)
    Proceed AVP (used)
    Classe' SSP-30
    Rotel 985 (and 976)
    My budget maxes out at around $3000 for the pre/pro. Can you give me some tips?
    Rob
  2. Vishwa Somayaji
    Vishwa Somayaji Stunt Coordinator
    Jun 10, 2001
    84
    If DPLII is not a must have, then you may take a look the new upcoming AVM 20 from Anthem. It is feature rich but lacks DPL2 and DTS Neo. Word is that they may upgrade this processor with those features in the future. Otherwise, it is good. It has XLR outputs, 7/3/1(coaxial/toslink/xlr) digital inputs, 7 s-video inputs, 2 component inputs with 100MHz bandwidth(good for 1080p), 3 independent zones and a record out and the feature list goes on and on. It will be in your price range after a decent discount. You can get more detailed info atwww.sonicfrontiers.com
    Good luck
  3. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    I would say you should look at the newest updated version (with ProLogic II and DTS-ES Discrete & ES Matrix, plus Neo:6) of the Integra Research RDC-7 pre-amp. Or their CD-ROM software/firmware upgrade kit for consumer PC's is $49 for the original release.
    It has everything (just no balanced inputs, but a 7.1 bypass input instead) you want plus THX EX, a phono input, an AC-3 laserdisc RF demodulator built in, Apogee Electronics professional studio-grade 24 bit/192 kHz DACs and ADCs and Master Clock jitter reduction, digital input upsampling, consumer software upgradeability, display re-labeling, FireWire IEEE input-ready (for digital DVD-Audio interface, and more), etc.
    They may even add flexible bass cross-overs in the future.
    Stereophile Guide to Home Theater classified it as a Grade AAA product and a super steal for the money. It was designed by THX, Apogee, Balanced Audio Technologies, and Onkyo.
    It may be a little bit over your $3,000 budget (retails at $4,000, although you can work it down), but well worth it. A lot of satisfied customers so far.
    Integra Research There were four authorized IR dealers in Texas when I did a dealer search.
    Dan
    [Edited last by Dan Hitchman on July 27, 2001 at 03:36 PM]
  4. Robert Standefer
    Sep 14, 1999
    85
    Thanks guys. I'll definitely check out the Anthem and the Integra. A couple of others that I learned about today are the Acurus Act-3 and the Aragon Soundstage. The Aragon in particular seems very interesting.
    -Rob
  5. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Robert, FYI, Klipsch bought out Mondial (parent company of Aragon and Acurus) and is phasing out the Acurus line (at last report). The exact direction of the Aragon line is uncertain. It will stick around (at last report) but speculation has it that the Aragon products will be 'downgraded' in the sense that they will be more mass market oriented (but, this is just speculation).
    http://www.hometheaterforum.com/bbs/equipment/28687.html
    [​IMG]
  6. Robert Standefer
    Sep 14, 1999
    85
    Vishwa,
    The AVM2 is $2795US MSRP, how much with the AVM20 be? I can't find any reviews or online vendors; it must be really, really new. The AVM2 seems pretty awesome; but like I mentioned, the AVM20 isn't out yet so I can't get a solid comparison!
    The AVM2 and AVM20 are on my shortlist. In fact, they are at the top of said list. Thanks for the heads up!
    -Rob
  7. Scott_Sylke
    Scott_Sylke Stunt Coordinator
    Jun 4, 2000
    84
    Robert,
    I have almost the exact set-up as you. I have:
    Sunfire THeater Grand II
    ML Aerious I's
    ML Cinema
    ML Scripts
    Sunfire True Sub Siggie.
    I would have to highly recommend the Theater Grand II. It mates perfectly with the Cinema Grand. Unless you REALLY NEED DLP II and center surround......you can't pass this up. If you look around on-line.....you can find them new for around $2500. The main reason I would recommend the Theater Grand II is because of their service and trade up policy. They will be coming out with a Theater Grand III next year, and all you have to do to upgrade is send in your Theater Grand II and $1000. I was told by a rep from Sunfire that the Theater Grand III will have all the new technologies. SO, if you are wanting to upgrade again in the future......I don't see any better deal out there.
    Scott
    a.k.a. KCWolfPck
    See my Home Theater Page .
    [Edited last by Scott_Sylke on July 27, 2001 at 07:18 PM]
  8. Darrel McBane
    Darrel McBane Second Unit
    Oct 8, 1999
    363
    110
    I'd like to add the B&K Reference 30. For under $3000 it may meet all of your needs and for music would compete with any others and well under your budget. I'm using the Acurus Act-3 and you can find many on E-Bay or Audiogon for a very good price. But the future of the unit is certainly an issue. Mondial has had upgrade options in the past and hopefully will offer a trade up at some time. But time will tell?! Good luck.
  9. Robert Standefer
    Sep 14, 1999
    85
    The Anthem AVM 20 has 10ch output (8.2), analog bypass on all analog inputs, balanced ins, balanced outs, 1080p-capable component video switching, and THX EX.
    That's quite a feature set for a pre/pro that, new, is $500-$600 more than a used Sunfire Theater Grand II. I really like the Sunfire, but the truth is, I've seen nothing about the TG III so I can't bet on it.
    The AVM 20 is at the top of my list until I can get some info about a new Sunfire pre/pro.
    -Rob
  10. Curtis_Edwards
    Curtis_Edwards Stunt Coordinator
    Jan 1, 2001
    101
    If you are interested in a silver Anthem AVM-2 I have one for sale. Had it for about 4.5 months.
  11. Vishwa Somayaji
    Jun 10, 2001
    84
    I see that the questions have been answered. I didn't see the thread for a couple of days. My apologies. AVM 20 sure looks good but the DPLII issue will deter a few from buying it right away. I have the anthem MCA series II amps and like them a lot. I would like to buy the AVM 20 myself. But, I hvae been holding out for DPLII. I am not going to buy it without either DPLII included or a firm commitment with a date. The going price on it should be in the 2600-2700 range.
    I did wrtie to Sonic Frontiers about the DPLII about a week or so ago. I am yet to hear anything from them. Wait and see. From all the reading I have done about the motorola chips there is going to be an upgrade. Question is , When?
  12. Curtis_Edwards
    Jan 1, 2001
    101
    I too have written to Sonic Frontiers about DPLII and here is the reply.
    "Why no DPLII - now there's a question that keeps coming up. The answer is really simple: The only microprocessor that currently handles it (as well as DTS-ES) is the SHARC. When Motorola provides to us (and all the
    other manufacturers using Digital DNA) the software code for DPLII, we'll be looking at the path towards upgrading through software. There's no telling when this might be."
    This response came from the Technical side of the house.
    Just wanted to let you guys know.
    --CUE
  13. Burke Strickland
    Burke Strickland Second Unit
    Jul 31, 1997
    271
  14. Burke Strickland
    Jul 31, 1997
    271
  15. Charles Gurganus
    Charles Gurganus Supporting Actor
    Mar 2, 1999
    689
    Robert, are you running version 2.01 software on the TA-E9000es? If not, I'd update that and then when the TA-P9000es 5.1 bypass comes out this fall, add that. That will solve any shortcoming the TA-E9000es may have.
  16. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    I was playing with a TA-E9000 this weekend and found it to have an exceptionally high quality look and feel (IMHO much better than the Denons)as well as extremely user friendly operation. Does anyone know if there is going to be a successor? The 9000 is physically limited to 5.1, correct?
    Also,
    There is a new Rotel coming in the $1500. range. Search this forum for info.
    Tom
  17. rajiv
    rajiv Stunt Coordinator
    Jan 31, 1999
    50
    Robert,
    Take my biased opinion and get the Proceed AVP used. There will be a major hardware/software upgrade for it next summer.
    Good luck,
    Rajiv...
  18. Dan Hitchman
    Jun 11, 1999
    2,713
    Robert,
    Just reiterating what I already said-- The best choice I've seen of the ones stated here is the Integra Research RDC-7. It's a friggin' steal for what you get... plus real DTS-ES 6.1 and ProLogic II (with the software upgrade), pro grade DACs, and pro grade Balanced XLR outputs for all 7.1 channels. Firewire IEEE ready.
    Dan
  19. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    There is a Lexicon MC-1 on Audiogon for 3K.
    Tom
  20. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    The B&K Ref 30 also uses the Motorola chip. I guess thats why they have been really quiet about DPL2.
    Tom
