Need a favor from anyone running an EX config
Discussion in 'Archived Threads 2001-2004' started by Jeremy Anderson, Jan 24, 2003.
  1. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    Hey guys- in doing some testing with my Onkyo, I came across an anomoly in EX decoding and wondered if I could find a couple other folks who could try an experiment on their system.
    Using a phase test for surround speakers (such a test signal is available on Avia, VE and even on any disc which has THX optimode). Play the phase test for surround speakers with EX processing on (make sure the processing is on!). When it goes "in phase" the sound should come out of the rear center-- but when it goes out of phase- what happens? Do you get sound from each of the rear side speakers, or do you get silence?
    If you could post your results and the model receiver or processor you use- that would be very helpful.
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    Yes, out of phase--sound comes out of the regular surrounds & in phase--out of the center surrounds.
    Pioneer 45TX.
    DJ
  3. Jeremy Anderson
    Nov 23, 1999
    1,049
    Thanks David. Need results from other people, so keep them coming!
  4. Michael Langdon
    Michael Langdon Stunt Coordinator
    Aug 29, 1998
    110
    Using the phase tests for the surround speakers on THX optimode, I get the following results with EX decoding set to 'ON' for my processor (Aragon Stage One):
    IN PHASE: sound comes out of rear center or surround back speaker(s)
    OUT OF PHASE: sound comes out of both surround left and right speakers
    Mike
  5. Jeremy Anderson
    Nov 23, 1999
    1,049
    Okay, anyone out there have an Onkyo they can try?
  6. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    Onkyo TX-DS898
    THX Surround EX: On
    Avia surround speaker phase test
    In phase: back surround speakers
    Out of phase: side surround speakers
  7. Jeremy Anderson
    Nov 23, 1999
    1,049
    Interesting... So Onkyo's line from last year decodes correctly. Anyone have one of the newer models to test? Particularly the SR600, 700, 800, or 900?
