NEC LT150 and a prog scan DVD
Discussion in 'Archived Threads 2001-2004' started by Eric Samonte, Aug 9, 2001.
  1. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    From what I read, this FP doesn't have component inputs and NEC offers a component to RGB (?) adapter. Now my question is, will using such an adapter not corrupt the progressive scan signal from say an RP91?
    I ask because I am set to get the former and if everything pans out, the RP 91 to go with it. If the latter won't work, I'd have to go HTPC..which is another different thread altogether.
    Eric Samonte
    Dito sa Pilipinas..may Hom Tiyeter rin kami!
  2. Dzung Pham
    Dzung Pham Second Unit
    Mar 10, 2001
    271
    No it won't corrupt your progressive output. The LT150 accepts progressive component input, it just doesn't have enough room for all the extra connectors. So the adapter is simply a VGA to 3 RCA breakout cable. You could actually just use a standard VGA to 5 BNC breakout cable and use BNC to RCA adapters for the three cables that you need. The LT150 automatically senses wether the connection is a standard RGB-VGA or progressive component.
  3. Eric Samonte
    Mar 31, 1999
    1,318
  4. Pete B.
    Pete B. Stunt Coordinator
    Jul 12, 1999
    58
  5. Dzung Pham
    Mar 10, 2001
    271
    This is a pretty good deal, and plus you would be supporting a forum sponsor and the forum itself.
  6. Eric Samonte
    Mar 31, 1999
    1,318
    I think you guys misunderstood me..I will be getting the NEC probably at our dear sponsor to help out our beloved HTF. What I was musing about was where to get the adapter cable. But rest assured, I am still grateful for your kind words.
    Eric Samonte
  7. ProjectorPeople
    ProjectorPeople Auditioning
    Aug 9, 2001
    4
    We are offering NEW NEC LT150's @ $2499.00 to Forum members.
    AJ Abrams
    Product Anlayst
    ProjectorPeople/AV Marketplace/PlasmaPeople/Home Theaterpeople/AVI
