kevinJscott
- Dec 5, 2004
User's Manual suggests that there PCMCIA LAN cards (plural) that work in the HT1100. I can't find any list of compatible devices. NEC sells a card...is that the only one that will work or are there others?
WLAN is apparently not supported. Anyone happen to have any success with that?
..Kev
..Kev
