1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
NEC HT-1100G Projector
Discussion in 'Displays' started by Nick.H, Feb 21, 2004.
  1. Nick.H
    Nick.H Stunt Coordinator
    Sep 18, 2003
    118
    Looking across the net for information on the NEC HT-1000 I found out about the 1100G model,
    Check out the specs,
    Specifications
    Panel Type: 0.7” DMD DLP (4:3)
    Resolution: 1024 x768
    Brightness: 1100 ANSI Lumens
    Contrast Ratio: 3500 (with IRIS)
    Video Systems: NTSC/PAL/PAL-M/PAL-N/SECAM
    Inputs: RGB Component, Composite, S-video, DVI-D, D-sub HD 15 pin
    Computer Inputs: VGA/XGA/SXGA
    Lamp life: 3000 hours (Eco mode)
    Image size: 40”- 300”
    Fan noise: 32 db (29 db Eco mode)
    Voltage: 100-240V 50/60Hz
    Size: 260mm(W) x 121 (H) x 319 (D)
    Weight: 7lbs (3.2kg)
    Warranty: Two years
    Features
    Variable IRIS allows you to adjust the contrast from 2000 to 3500
    Sweetvision 2 technology further enhance the contrast and black level
    3D Reform technology and vertical shift ensure the image always on top and in proper aspect ratio
    Faroudja DCDI - the best chip in industry to eliminate jagged edges
    DVI input with HDCP compliment and allow 1:1 mapping of pixel - excellence for Digital TV
    Sealed optics for reduced maintenance and better performance in dusty environment
    What you all think?
    $7200.00 RRP AUD
    http://www.hdaudiovisual.com.au/display/ht1100g.htm
  2. David Parrish
    David Parrish Stunt Coordinator
    Jan 24, 2004
    128
    Is this the Aussie version of the HT1000?
    Looks nice. But considering you can get a BenQ 8700 for a thousand more( street prices), I'd go with the 1280x720 chip.
