NBC Tonite Show
Discussion in 'Displays' started by Kevin_Welch, Dec 12, 2003.
  1. Kevin_Welch
    Kevin_Welch Agent
    Jan 30, 2003
    31
    I have a mitsubishi 55" hd rptv and weather i am watching local hd or dtv i always get closed caption in spanish on the tv is it my tv or NBC feed thanks K~
  2. ChuckSolo
    ChuckSolo Screenwriter
    Jun 26, 2003
    1,160
    There is a setting on most modern TV's user menu that allows you to turn on and off the closed caption and also to set the language.
  3. Kevin_Welch
    Kevin_Welch Agent
    Jan 30, 2003
    31
    what has me puzled is that it only happens on nbc
  4. ChuckSolo
    Jun 26, 2003
    1,160
    That is really bizzare!!! Have you checked your settings yet though. It could be that only the local NBC station in your area does the CC 24/7.
  5. Kevin_Welch
    Kevin_Welch Agent
    Jan 30, 2003
    31
    It only happens on the tonite show, i guess i need to learn spanish[​IMG]
  6. ChuckSolo
    Jun 26, 2003
    1,160
    Are you sure that your TV isn't set to SAP in the user menu under sound? Check that out.
