Name your top three choices for speaker cables
Discussion in 'Archived Threads 2001-2004' started by Ryan Cruz, Apr 11, 2002.
  1. Ryan Cruz
    Ryan Cruz Stunt Coordinator
    Apr 2, 2002
    139
    I'm about to but cables for my PSB Image speakers, and I'm wondering what you guys consider to be really good cables for them. If money was no object, what would be the top three choices (top three coz I only have limited choices where I live)
    Thanks!
  2. Jeffrey Chin
    Jeffrey Chin Second Unit
    May 22, 2001
    483
    cardas
    nordost
    alpha core goertz
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    sound king 12 gauge. take the money you save, get some dvd's, pizza and maybe a 1/4 keg of a local microbrew and invite some friends over.
  4. SanfordL
    SanfordL Stunt Coordinator
    Mar 1, 2002
    101
    Just a question, will you run these wires in the walls, ceiling, or anywhere else that you'll need UL certified stuff? If not, then check these out.
    http://www.heartlandcables.com/ might be an option to although they are not a "money is no object" kind of place. 11 guage Canare Wire might be worth a look though even if they don't kill you on the price. They look nice, although I haven't heard them (yes, I know Chu, wire is wire is wire.) Some say the wires make a difference, others don't. The value is in the eye of the beholder, but these look nice, look well made, and should work for up to about a 50' run.
    Straight wire Rhapsody S (hey, if you want to burn cash, here's one way to do it :) http://www.audioadvisor.com/store/pr...ble%20-%20Pair
    Or, if you really want to mortgage the house, check out the Cardas Golden Reference http://www.audioadvisor.com/store/pr...e% 20-%20Pair which cost more than some folk's car for a normal sized HT set-up.
  5. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    Ryan,
    Two answers depending on your budget...
    "High End" Audiophile:
    Cardas (I have the Golden Reference and its worth it!)
    Nordost
    Kimber Kable Select
    Budget Audiophile:
    Alpha Core Goertz
    Audioquest
    Kimber Kable (entry level models)
    Good luck with your shopping! [​IMG]
    Lee
  6. HarryR
    HarryR Agent
    Dec 18, 2001
    38
    What do you guys think of the Cardas Crosslink. Over at Michael Percy it is $3.50/ft
  7. John Besse
    John Besse Supporting Actor
    Jun 22, 2000
    569
    Trinity, FL
    I like
    Tara Labs
    Audioquest
    Kimber Kable
    Those are my choices!
  8. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    John,
    I forgot about Tara Labs - good stuff!
    Harry,
    Cardas Crosslink is good for their entry level cable. If you can move up to Quadlink I recommend it. I had this before the Golden Reference and it was good value for money.
    Lee
  9. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    I have had good results with Nordost. Currently evaluating a JR design from RhinoCables.com and they are keepers. Boldercables.com and DiyCable.com sell this JR CC design. Using Canare 4S11 for the surrounds.
  10. Ryan Cruz
    Apr 2, 2002
    139
    Ok what do you guys say about Van Den Hul vs. Tara Labs?
  11. Mike Knapp
    Mike Knapp Supporting Actor
    Aug 4, 1997
    644
    20
    Mike
    One small correction, you are buying cables for your system....not your speakers. Everything plugged together must work in concert.
    I use a pair of BetterCables for my audio only rig and I have some custon made IXOS for my Home Theater rig.
    I can recommend either with personal experience to back it up. You may find success with many others as well.
    Keep in mind that recommendations (or dismissals) without personal experience is like someone giving you directions that just arrived in town themselves.
    Good luck!
    Mike
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Just what is it that you're looking for Ryan and what are you presently using? You seem to be bouncing around a bit.
  13. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
  14. Ryan Cruz
    Apr 2, 2002
    139
    Chu Gai,
    I just bought PSB Image 2B's and the New Alpha Center. I was wondering what would be good but not extravagantly priced cables that I could use for them. I was only worried about my surrounds since they would be needing a good length of a wire.
  15. HankM
    HankM Second Unit
    May 15, 1999
    332
    MIT
    Audioquest
    Kimber Kable
    I currently use MIT Terminator2 Bi-wire for my mains.
